Labview 7.0 is compatable with Labview Imaq6.1 , vision builder 6.0 and Imaq run time engine 6.0.
Sir,
My system is PXI 8174 and i an using NI 1411 card for my application. I want to know the compatability of the softwares. Whether Labview 7 is compatable with Labview Imaq 6.1 , vision builder 6.0 and Imaq run time engine 6.0.
(2,546 Views)
Assuming you meant IMAQ Vision 6.1 instead of IMAC 6.1, this software was intended to run on LabVIEW 5.1, 6.0, and 6.1.  I have heard of it being used with LabVIEW 7 on occasion, so it may be possible to make it work, but this has not been tested and is not officially supported.  Vision Builder 6.0 should run; however, it was developed long before LabVIEW 7.x and will not generated code for LabVIEW 7.0 and later.  The Vision RTE version should correspond to the version of Vision you are using.  For instance, if the program was developed with Vision 6.1, the computer should have the Vision 6.1 RTE installed.  With this being said, if you plan to use LabVIEW 7, I recommend updating your other software.
Ryan M.
(2,533 Views)
