Labview 6
Whats the difference between Labview 5 Full and Labview 6 Full? Cause i just
got labview 6 Full upgrade out of nowhere for free from NI, and I was
wondering if there is any advantage to using it?
Rob
(3,248 Views)
I just got back from NIWeek in Austin.  If you have the choice between 5.1 and 6i, version 6i has MAJOR enhancements that are definately worth the switch.  Also, here is your answer from today's email from NI:LabVIEW 6i released August 16* New 3D Graphical User Interface* Lock objects in front panel (so will not move indepently)* New Waveform Data Type* New VIs for adding/removing array elements* Automatic Wiring* Internet/Datasockets made even easier* Create DLLs (for those who have Application Builder)Options for Upgrading:http://www.ni.com/suite/pro_edition.htm (If need App Builder/toolkit as well as new LabVIEW 6i)http://www.ni.com/advisorComplete New Features Listing:http://www.ni.com/pdf/manuals/321780c.pdf  LabVIEW 6i Release Notes--Michael Munroe    Mailto
:mmunroe@abcdefirm.comA Better Complete Development Engineering FirmSan Mateo, CA  94403  http://www.abcdefirm.comGet Clarity at http://www.symmcorp.com/mmunroe Rob wrote:Whats the difference between Labview 5 Full and Labview 6 Full? Cause i justgot labview 6 Full upgrade out of nowhere for free from NI, and I waswondering if there is any advantage to using it?Thanks,Rob
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
(3,248 Views)
Can I ask you to please not post in HTML? Agent doesn't support HTML natively
and your message must be opened in a browser.
On Mon, 21 Aug 2000 10:21:03 -0700, Michael Munched
* Automatic Wiring
https://www.ni.com/en/shop/advisors.html
https://www.ni.com/pdf/manuals/321780c.pdf  LabVIEW 6i Release
>Notes
Michael Munroe    Mailto:mmunroe@abcdefirm.com
Rob
SolidWorks Research Partner National Instruments Alliance Member
Christopher Dubea Phone: (504) 847-2280
Vice President of Engineering Fax: (504) 847-2282
Moving Parts L.L.C. email: cdubea@movingpart.com
P. O. Box 6117 URL: http://www.movingpart.com
Slidell, LA 70469-6117
(3,248 Views)
