Labview 6.0.2 Error: Drawmgr.cpp, Line 417
I was testing a Labview6.0.2 test step in TestStand 2.0.1f1 and closed TestStand without closing the Labview code for the test step. Error occured in Labview 6.0.2: Drawmgr.cpp, Line 417. What is this? How would it affect Labview and TestStand? How to fix this failure. Thank you.
(3,079 Views)
Hi Valen Li,
this is an internal error of LabVIEW. Occurs this error again, when you try to open the VI with LabVIEW again?
If this happens your VI is corrupt. You can ask NI to correct it or you have to rewrite it again.
If this occurs only at runtime and it is reproducible report it to NI.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,079 Views)
Hello Waldemar,
Thank you for your information. The same error was duplicatable only once. I tried to duplicate the problem again and it did not show. The test vi run properly with and w/o having TestStand opened. Hopefully, it did not corrupt any other VIs. Thanks again....
(3,079 Views)
