Labview 5.1.1 crashes when I use Invoke Node or Property Node
I am using Labview 5.1.1 on a windows 98SE machine.
Under Functions Palette if I click on Communications and if I select ActiveX
and then if I select Property Node or Invoke Node Labview just hangs up.
Could you suggest me the fix for this issue.
Premal
(2,577 Views)
Premal --
Don't know of anything off the top of my head that would cause this. Have you tried loading one of the ActiveX objects that come with LabVIEW? Is it possible
something on your harddrive is corrupted? If so I would suggest running scandisk and possibly re-installing LabVIEW.
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,577 Views)
