Labview 2018 - Error 1124 with Std Deviation and Variance.vi
I have just been struggling with exactly the same issue so this is definingly a LabVIEW bug.
I upgraded my entire project from LV16 (32) to LV18 (32) and the builds works on some computers and not on others. I have not yet been able to see what causes the difference between the different computers.
“I think I will try compiling with the option for removing unused polymorphic VIs turned off (so the unused ones are included).  Maybe this will help...”   --> This did not help for me!
National Instruments, please fix this! It has cost our company several hours of extra work and a lot of headache.
Message 11 of 17
(1,122 Views)
+1 for me to - just ran into this program this morning and it was a massive hassle as the systems were being used overseas. Surely this is an easy fix. It only seems to occur for me when I open code from earlier LV versions into Labview 2018 and build an executable. The workaround "works" but sucks as it should be an easy fix.
Message 12 of 17
(1,103 Views)
http://www.ni.com/product-documentation/54795/en/
Seeing as the post before yours was a NI Employee calling it a bug, sounds like they'd agree.  Are you running the patch from the notes I linked?  It'd appear the 2018 f2 patch has a fix for the VIs referenced in this thread.
Message 13 of 17
(1,086 Views)
Is there a better resolution to this yet?
I did an initial installer for a new program and it ran fine at first. I needed to make some changes so I updated (ran installer with no additional installer packages) and now its throwing up the "Labview: (Hex 0x464) VI is not loadable."
An error occured loading VI "NI_AALBase.lvlib:Std Deviation and Variance.vi"
I'm running LV2018 18.0f2
Message 14 of 17
(1,037 Views)
I have not found a better solution to this given the version of LabVIEW.  Perhaps LabVIEW 2019 fixes this?
Message 15 of 17
(1,030 Views)
I can confirm that right-click and select "Replace with SubVI Contents" fixes the issue and luckily for me I only had one instance of the subVI that was in a relatively convenient spot to break it out into its individual components.
Still frustrating, but at least it was documented in this thread and an easy fix.
Message 16 of 17
(1,026 Views)
Agreed: frustrating and stupid.  And yes, at least there is a fix.  Hopefully it is (or will be) fixed in a future version...
Message 17 of 17
(1,018 Views)
