Labview 2014, Windows 10, Modulo FPGA, cRIO 9075
Tengo un compact RIO 9075 y la licencia de labVIEW 2014 ¿Alguien sabe si puedo utilizar los módulos del real time y del FPGA con Windows 10?
(1,071 Views)
Hi Gera,
@GeraMX wrote:
I have a compact RIO 9075 and the labVIEW 2014 license. Does anyone know if I can use the real time and FPGA modules with Windows 10?
The general answer is: probably yes!
  • NI does not support LV2014 anymore.
  • NI never supported LV2014 on Win10 computers.
  • But: You still can install LV2014 and its modules on Win10 computers…
Next problem is the FPGA module:
  • You use a very old cRIO target, requiring an even older version of the Xilinx compilers! You cannot even install that compiler on a Win10 computer…
  • Suppose you have a valid SSP contract you can use the FPGAFarm compile service provided by NI to compile your cRIO907x FPGA bitfiles…
(1,036 Views)
Great, thank you for your answer
(1,015 Views)
