Labview 2013 report generation toolkit word 2010 insert table problem
I am currently evaluating LV2013 with respect to the report generation toolkit for use with word 2010. My Vi/program won't insert the correct table and gives me an error message. see below:-
Exception occured in Microsoft Word: The requested member of the collection does not exist.Help Path is wdmain11.chm and context 25421 in NI_ReportGenerationToolkit.lvlib:Word_Insert_Table.vi->NI_Word.lvclass:Append Text Table to Report.vi->Word Table save.vi
I have since run the following word example.vi provided by NI within LV2013 office examples:- Growable table.vi. this gives me the same error!
Exception occured in Microsoft Word: The requested member of the collection does not exist.Help Path is wdmain11.chm and context 25421 in NI_ReportGenerationToolkit.lvlib:Word_Insert_Table.vi->NI_Word.lvclass:Append Text Table to Report.vi->Growable table.vi
It would seem that regardless of my own Vi there is a fundamental problem in the office example vi.
I have found examples of a similar problem in LV2011/2012 but the work around code doesn't seem to match the LV2013 vi's code for a direct replacement.
Can anyone help/shed some light on this?
Thanks in advance,
Dan.
(5,210 Views)
Hi Dan,
I am an Applications Engineer at National Instruments. Can you please provide me with the exception code?
NabilahF
(5,155 Views)
Hi NabilahF,
the code is:-
-2146822347
Many thanks.
(5,150 Views)
Hi Dan,
Thank you for the reply. This is a known issue in LabVIEW 2013 and we are working towards fixing it in a later version. The example seems to work in LabVIEW 2011 just fine. There is a potential work around that does appear to work, but I've not tested it on my machine. You can copy the vi's from 2011 to 2013 and the example works.
I hope this helps. Have a nice day!
NabilahF
(5,110 Views)
aaaahhhh boooddyyy filter!!!
(4,888 Views)
have you already fixed on this error code?
i have got this error message in 2014
(4,762 Views)
Because the upgrade of Word from 2007 to 2010 I needed to upgrade an existing application from LabVIEW 2009 to 2013. This didn't work because of the insert table error. I discovered that the problem is the vi called "Word_Insert_Table.vi" located in the ..Program Files (x86)\National Instruments\LabVIEW 2013\vi.lib\addons\_office\_wordsub.llb. There is a "Cut" command implemented, this command removes the created cell instead of clearing it. Therefore the table will be filled half and then returnes with an error. I have removed this command. I have posted the changed vi (LV 2013).
(4,666 Views)
