Labview 2013 (32 bit vs 64 bit)
I have subVI to read the current from the Keithley 2400.
1. When I run it under Labview 2013 (64 bit) is no error
2. When I run it under Labveiw 2013 (32 bit) is ERROR
   Error Code ID = -201 - Invalid while in local
   Error Code ID = -420 - Queary Terminated
How can I fix this subVI to run under Labview 2013 (32 bit) ?
Khanh
Message 1 of 10
(4,234 Views)
As a first step, you could show us the subVI. Where did you get it? How are we supposed to know what it does? Could it be that it is calling a third party 64bit dll?
(These don't look like LabVIEW errors, so they are probably generated by a third party component)
Message 2 of 10
(4,224 Views)
Sorry, Attached is the subVI, I wrote it myself.
Message 3 of 10
(4,208 Views)
Code Note: The Sequence structure appears to be completely unnecessary.  Perhaps in the situation you wish to use your wait, make a separate sub VI.  But other than that, the error cluster is driving sequence.
Speaking of error cluster: have you tried some basic debugging to determine when the error occurs?  Place probes along the error cluster, create a conditional breakpoint, or even use highlight execution.  It's a little harder for us to reproduce the error of a subVI.
Message 4 of 10
(4,182 Views)
Error at GPIB Read:
Output of the GPIB Write is OK but output of the GPIB Read is error. But the same subVI, if I run by Labview 2013 (64 bit) no error, unfortunatly the rest of the program (other instruments communication) are running with Labview 2013 (32 bit). That's why I would like to fix this to run under Labview 2013 (32 bit).
Please help. Thanks
Message 5 of 10
(4,169 Views)
I would have to say whatever is initializing the instruement is not able to do so.  Hence the "Error Code ID = -201 - Invalid while in local" error.  (It can't set the instrument to "Remote" mode.)  Furthermore, I would hazard a guess that this is due to what mentioned about the 64-bit dll.
Swapping between 64-bit and 32-bit anything - not just LabVIEW - can have unexpected results due to dll issues.
Bill
CLD
(Mid-Level minion.)
Message 6 of 10
(4,163 Views)
I guess the summary is that you are looking in the wrong place.  Other than questionable LabVIEW practices, there is nothing really wrong with this VI.
Bill
CLD
(Mid-Level minion.)
Message 7 of 10
(4,161 Views)
Thank you all for your help. Now, I have both Labview 2013 (32 bit) and Labview 2013 (64 bit) in the same computer. How can I uninstall the Labview 2013 (64 bit) from the computer. Hopefully this will solve the problem.
Message 8 of 10
(4,141 Views)
It won't.  You're very far off the mark.  It's the Keithely driver that you are sort of using, not LabVIEW.  It probably installed the 64-bit dll.  You'll have to find a way to install the 32-bit dll, either alongside or without the 64-bit driver.
Bill
CLD
(Mid-Level minion.)
Message 9 of 10
(4,124 Views)
There is a Keithley 2400 driver at http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=25B255F3AA83660EE0440003BA7CCD... that does not use a dll. Compatible with all versions of LabVIEW and any os.
Message 10 of 10
(4,118 Views)
