Labview 2011 FDS (64bit) crashes when saving a vi with MATLAB node
After running a vi which includes a MATLAB node, the vi cannot be saved, because Labview crashes every time with error: "DAbort 0x1A7102DF in fpsane.cpp".
Why does a MATLAB node with simple array I/O corrupt LABVIEW's sanity ???
I have attached a minimum configuration, which gives a reliable crash. First run, then push save.
Configuration: Windows 7 (new installation), Labview FDS (64bit), MATLAB (64bit)
Message 1 of 14
(6,067 Views)
I have the same problem. It only occurs when I have run my program first, stopped it and then try to save changes I have made to the block diagram (after stopping the program).
The crash is specific to something inside the program (doesn't occur in new and relatively simple VIs).
I can work around it by only making changes to the block diagram before a run. And by restarting Labview after every run.
More details (from the log file): it appears to be related to fpsane.cpp line 469.
Does anybody know how to solve this?
Milan
Message 2 of 14
(6,007 Views)
Do you use the same Configuration (Windows 7, 64-bit mode for Labview and MATLAB) ?
My workaround is currently the same as yours. But this is definitly not the way it should work.
I try to escalate the problem to NI support here in Germany. Hopefully we get some feedback.
Roman
Message 3 of 14
(6,004 Views)
I run nearly the same configuration: Windows 7 Enterprise, 64 bit, Labview 2011 (also 64 bit).
No Matlab though...
I tried to run your file, to see if I could find overlap with my own program. However, yours requires Matlab...which I dont have.
Milan
Message 4 of 14
(6,001 Views)
I have exactly same problem. Is ANYBODY of NI going to respod / address the issue??
Message 5 of 14
(5,973 Views)
I have received a Service Request Number from NI, which means the problem is now in the pipeline. They are trying to reconstruct the issue, however NI-support in Germany is not allowed to install MATLAB (...!). The subject is escalated to US (hopefully THEY have MATLAB!). But no answer so far.
Roman
Message 6 of 14
(5,954 Views)
Well, I dont have Matlab and get the same error. I think this might be related to the known issue of LabVIEW 2010 32-bit in fpsane.cpp line 422, which was resolved in LabVIEW 2011 32-bit.
I think they overlooked the 64-bit version 🙂
Keep me posted!
Milan
Message 7 of 14
(5,949 Views)
did anybody could solve or got a work arround this problem?
I am getting the same error code when I use the Call Library Function to call external DLLs in my application.
I am using the following system configuration:
- Windows 7 32bit with SP1
- LabVIEW PDS 2011 32bit
Additionally to this error I am getting the following message (Ausnahme: Access violation (0xC0000005) bei EIP=0x00C0503F) (see attachments)
Note: calling the same DLLs using previous LabVIEW versions (8.2) works fine.
Message 8 of 14
(5,884 Views)
hi,
i also had problems with crashing. i solved my problem for application with running labview.exe - 32-bit on na 64-bit machine (labview version: 2011).
Message 9 of 14
(5,828 Views)
Same problem here, but no MatLab.  I got it when replacing a bitmap on the front panel with an updated version.  LabVIEW version 11.0.1f1.
Certified LabVIEW Developer
NI-VLM Administrator
Message 10 of 14
(5,766 Views)
