Labview 10, update values in scada system
Hi everyone,
I'm busy building a scada application with Labview.
It is almost finished but I still have one problem.
My problem is as follows:
When I go to pages in my scada system I can read out the values.
But when I'm switching back to a page(which I allready looked at), I can not read out any values.
So the first time the values are visible, after that, they are not visible anymore.
When I delete the page in the Distributed System Manager, and then switch back to the page, the values will be shown again.
The problem appeared after I switched from Labview 8.2.1 to Labview 10.
Can someone tell me where it could went wrong?
Did anyone had the problem before?
I hope that someone can help me.
Kenny
(2,720 Views)
I'd like to know that you still have the same problem or not.
If you didn't solve your problem you can check the NI DSM. Besause its behaviour is different in different version of LabVIEW. NI DES only displays the active screen variables and not the rest. So be sure that it isn;t the issu.
Hossein
(2,646 Views)
I think that you don't have any problem and I will close this forume. If you have another questions, we will hear them from you.
(2,630 Views)
