12-04-2007 12:14 PM
12-05-2007 08:25 AM
Matt,
You should use the Windows Task Manager program, go to the Processes tab and sort the CPU column. Then you can see which process is consuming the CPU. Then you can contact the supplier of this process/program and check with him for the reason.
Another approach may be to close one process after the other and see when the CPU returns to normal.
Mike
12-08-2007 06:15 PM
Thanks for the idea Micham,
The task manager shows the nicitdl5.exe and taskmgr.exe using up most of the CPU usage. If I stop the services (Labview crashes of course) the cpu usage on the XP box was done under 10%. I haven't tried this on the Server yet, I will next week once I'm back onsite. I have detached the database a couple of times in MAX and recreated a new one. That seems to help the problem for a few weeks.
To support my programming skills... the same application works fine on another computer, but this test computer doesn't have the modbus, kepware or Win911 installed (so its not working as hard). Basically I was using the this test unit to run the cRIO and the RSlogix interface while testing.
Any advice would be greatly appreciated!
Matt
12-08-2007 11:48 PM
Matt,
I suggest that you should close the following process one by one and see if the CPU percentage is going down after each close.
Modbus
Kepware
Win911
If the CPU is going down after you close one of the above processes, then you know which of the processes is the "main suspect".
Mike
