LabView2013 error API-MS-Win-Core-RtlSupport
I have a old project developed with LV8.6, running on MS Windows XP. All is ok.
After project migration from LV8.6 to LV2013, the executable file built doesn't work. During start up I have this error : 'Impossible to run the application. API-MS-Win-Core-RtlSupport-L1-1-0.dll not found. New installation of the application could solve the problem'.
Do you have any idea?
In the same PC I have others LV2013 project correctly installed without any errors.
(2,479 Views)
I found the Windows DLLs document "api-ms-win-core ..." Not Found When Calling LabWindows / CVI DLL document; although it concerns a problem that is quite different from yours, it could provide you with useful ideas to deal with it. If not, I ask you if you can send the executable (and maybe also the source code) in attachment, to try to reproduce the issue.
Alessia
P.S .: The old LV 8.6 project ran under Windows XP, but on which operating system is LabVIEW 2013 installed? Still XP?
(2,420 Views)
