LabView talking with Simulink model
I have a problem sending a real number to a Simulink model. Simulink only understand the format with full stop as indicater (2.5) but labview only want to send with comma (2,5).
I´m Using a danish windows XP, but I can´t see that this is the problem, because I have tryed to change the settings to match the english number system.
Please point me i the direction to fix this problem.
M.Olsen
(2,573 Views)
Hello M
In LabVIEW you are able to set the decimal point in Tools >> Options >> Front Panel. You are able to set it up to use the localized decimal point. When the localized decimal point is not used then its a dot that's used as decimal point. If you change that setting remember to reboot LabVIEW.
Regards
Mohadjer
NI-DK
Message Edited by mohadjer on 09-27-2005 08:30 AM
(2,568 Views)
thanks for the reply,
(2,554 Views)
