LabView signal conversion HELP
Hello, I am very new to labview so here is my issue.
I am taking a 0-10 volt signal and recording it; I want to convert and display the data in PPM (parts Per Million).
How is the best way to do this, help.
(2,988 Views)
Math.
Do you have a conversion factor from volts to ppm?
Then just multiply the volts by that number.
(2,978 Views)
You'd need to scale it according to the proportions in your measurement.  What does a reading of 10V represent in PPM?  Does 0V represent 0PPM?
Jim
(2,977 Views)
Where is this signal coming from?  I'm guessing a sensor of some sort.  What does the data sheet of the sensor say to do to convert your signal?
(2,972 Views)
