LabView shutting down when runing VI
Hi all
I've just started learning LabView; I need it to create an interface of a camera to a PC. I am havin a problem as each time I run my Vi it just shuts down without giving anf errors or exceptions(?).
In this VI, I used a Call Library fuction Node to call one of the fuctions provided with the camera software.
Thanks in addvance..
(2,939 Views)
It seems like the Call Library Node is not configured correctly. Be sure you are using the right calling conventions. See http://zone.ni.com/devzone/conceptd.nsf/webmain/B26A875ACA51C567862567CA0055FF24?opendocument for more details.
(2,939 Views)
The method I am clalling is given in the API as follows:
Syntax:
PXL_RETURN_CODE PimMegaStartPreview(
obligatory,
IN HANDLE hImager (this is an U32)
Optional
Parameters,
IN LPSTR title
="PL1394 Camera Preview",
IN U32 style
=WS_OVERLAPPEDWINDOW|WS_VISIBLE,
IN U32 x=0,
IN U32 y=0,
IN U32 width=-1,
IN U32 height=-1,
IN HWND parent=NULL,
IN U32 nId=0,
IN int PreviewDataThreadPriority
=THREAD_PRIORITY_BELOW_NORMAL,
IN int PreviewDrawThreadPriority
=THREAD_PRIORITY_BELOW_NORMAL);
There i
s only one parameter which is obligatory and the remainin are optional. I tried calling the method with the first parameter only but it didn't work and the same problem occured.
Do you know how can represent a HWND variable using LabView and how can I set it to NULL value.
Thanks very much
(2,939 Views)
You will need to specify all of the arguments. (Default arguments are just syntactic sugar; The arguments are always there, but the C compiler automatically puts the default arguments in if they are unspecified.)
Also, be sure to check the calling conventions (stdcall or cdecl).
(2,939 Views)
Thanks very much, it worked at the end
(2,939 Views)
