LabView project refactoring strategy
Hallo,
I'm pretty new to LabView (I had some experience with CVI in the past years and a quite big experience in standard coding) but now I have been tasked into refactoring a pretty big project composed mainly by subVIs distributed over several folders/subfolders.
I have been asked to:
1) migrate from a source distributed solution to a compiled application;
2) merge subVIs into packed libraries (where possibile);
3) create setup to distribute the application.
I created the project (it was missing) and started creating the main executable and it seems to work right now.
I would like to go on and merge VIs into Packed Libraries but I have a doubt:
bindings between subVIs merged into Packed Libraries will survive the procedure or I will need to replace every reference?
I'm working on LabView 2013 SP1.
(1,567 Views)
Accepted by topic author michele.santucci
In order to create a packed library you first have to create a LabVIEW library (.lvlib). If you create the libraries in the project you created and move VIs into the library within the project (dragging the VI into the lvlib like a virtual folder in the proejct) then LabVIEW should be able to handle that without you needing to relink things.
When you build that library into a packed library you can right-click the library in the project and replaced with the packed library but I'm not sure when that feature was implemented. I would also make sure that whoever requested you move code into packed libraries has good reasons for doing that.
(1,532 Views)
