LabView program for XBee
Dear forum,
I'm a senior student who has no more than basic exp with LabView and seriously need help right now. I have a wireless pH sensor system that use XBee as a mean to transfer data and i have finished everything but the last step which is read data between XCTU and LabView. Does anybody has a similar example of the program or could tell me where to start with. The XCTU gives me all the Hex code by the way.
(3,430 Views)
Are you using an XBee in a dev board on the computer-side of this communication?  If so, you should be able use the LabView VISA serial port VI to send/receive over the radios without having to use X-CTU.
(3,420 Views)
