LabView prog. da SUN a Windows
Hi all
I have many programs running in Labview 6.0 on a Sun Solaris system.
I would like to know if I can run those same programs on a new version of Labview for PC (windows XP).
(2,859 Views)
MOst likely you will be able to run your program, howver interfacing with hardware might be different,  if you have used the proper path building routines, there shouldn't be a problem either.
You can download a testversion of LabVIEW here to see what happens.
Ton
My LabVIEW Ideas
(2,848 Views)
