LabView linux : error 7 when accessing shared library file
Trying to wrap a shared object to LabVIEW Linux using Call Library Function Node VI I get an error 7 (non existing or moved file or missformed path) while the file is existing and path ok (I used FileDialog to be sure to have the correct path).
This is really surprising since when opening 'Configure ...' menu I am able to select my shared object file and LabVIEW lists correctly the functions of the contained in the library.
I don't how to deal with such an error and need help (I spent a lot of hours in trying to find the solution by myself). Surprisingly there is not example related to that in the Linux release of LabView (note: I run LAbVIEW 9).
Many thanks in advance for any comments
Christophe
Message 1 of 1
(3,139 Views)
