LabView --> Control Module --> Motor
Hey everyone,
I am new here. I am currently working for a way to control a motor(dynamixel mx-28) have the robotics ad-in for labview and it has specific module/commands for my motor. My plan was to connect the motor to lab view via a control module (CM-700). After wiring everything up, I was able to verify that the control module is succefully communicating with LabView but the motor still does not move.
I used a program called roboplus that came in with the CM-700 and it was able to control the motor, this verified that the motor does wor/wiring is correct.
My ultimate goal is to have labview and an external controller/joy stick to control the motor.
[Links]
motor: http://support.robotis.com/en/product/dynamixel/mx_series/mx-28.htm
CM-700: http://support.robotis.com/en/product/auxdevice/controller/cm700_manual.htm
Possible joystick: http://www.digikey.com/product-detail/en/27800/27800-ND/2470145?WT.mc_id=IQ_7595_G_pla2470145&wt.src...
THANKS!
(3,252 Views)
So where is your LabVIEW code (this means a VI, not a .jpeg or a .png, unless, of course, it is a LabVIEW Snippet ...).  We need to be able to "poke" at your code, see what is in the "other Case statement", examine the Express VIs (booo!), etc.  I know you want to learn how to do this yourself, so "do it yourself" and we will help when you show us something that doesn't work.
(3,236 Views)
