LabView equivalent to running batch files using the "shell" command (VisualBasic)
I'm converting a VisualBasic app to LabView and am having trouble figuring out how to run a batch file with LabView.
The VB code that I'm trying to replicate is:
'UNLOAD RTX DRIVERS
Dim ProcessId As Long
ProcessId = Shell(App.Path + "\UnloadReloadRTX.bat", vbNormalFocus)
Wait 400
I haven't found a LabView equivalent to the Shell command. Any suggestions will be appreciated.
thanks,
Todd
(2,941 Views)
It seems as if this question pops up every week. Use the System Exec.vi found under Funtions - Communications palette. It is the equivalent of Shell.
- tbob
Inventor of the WORM Global
(2,941 Views)
Thank you for your input
(2,941 Views)
