LabView & drivers
Hi
A have card - stepper motor driver
I must create drivers for LabView
How ?
Please Help.
(3,119 Views)
Tomek wrote:
> Hi
> How ?
> Please Help.
You dont give much information, but I will give it a shot.
First you need to know what the interface is.
Serial, GPIB, or is this a card plugged into the PC ?
Next, do you have the documents that describe the command set ?
If this is a plug in card, do you have a dll or some other vendor supplied
software?
There are probably not too many commands for a stepper.
Forward, reverse, number of steps for starters.
There may be step size, speed, position (if it has a syncro) and limits.
Once you decide on the first two items it will be much easier to determine
how to proceed. Let me know if you need more help.
Kevin Kent
(3,119 Views)
