LabView doesnt recognise installed .Net
Yesterday when i tried to access ".Net Element zur Palatte" (.Net Element Palatte in English?), i got an error stating that for .Net Functions and Applications atleast .Net Framework 2.0 is required. However i have .Net Framework 1.1, 2.0. 3.0, 3.5 and 4 installed on my Computer. Then we uninstalled LabView 2009 completely and installed LabView 2010 and still it shows the same error.
Can someone help with this?
(3,461 Views)
Hi Arson,
when you say, that when you tried to acces it yesterday and you got an error, that it worked before? Did you do anything else than installing LabVIEW 2010 after that?
Manuel
(3,422 Views)
I never tried it before. No i did not do anything else after that.....
(3,391 Views)
Hey Arson,
have you tried to reinstall your .Net Frameworks on your computer? If not you should try that, it may solve the problem. You said that you have also .net framework 4.0 installed, therefore i just wanted to inform you in advance about a known issue there.
You may wanna take a look at this KB:
http://digital.ni.com/public.nsf/allkb/2030D78CFB2F0ADA86257718006362A3?OpenDocument
Manuel
(3,387 Views)
Hi Arson,
could you tell me whatkind of OS you use?
Manuel
(3,373 Views)
