LabView crashes when writting file
I have a big problem with LabView. In my Vi I capture 6 waveforms from a
DAQ Card with a SCC Module. When combining the 6 signals to an array and
write them to an file there is no problem but there is also no time
information. When merging the 6 signals and trying to write this to a
file, Lab View crashes without any error code or something. Perhaps
anybody knows a solution for this problem.
Achim Kanert
(2,698 Views)
Dear Achim,
Thank you for contacting National Instruments.
I have a few questions. How is LabVIEW crashing? Does the crash occur if you use less waveforms? Like two waveforms? What VIs are you using? If possible, could you shrink the problem down to the VI that produces the problem? Is there a way you could send me a VI that exhibits the same problem you are having? I've been trying to reproduce your problem and LabVIEW never crashes.
Let me know as much relevant information that is possible so that I may investigate this issue.
Thanks again and have a great day!
Chad AE
Applications Engineer - National Instruments
(2,698 Views)
LabView crashes without any ErrorCode. A Popupwindows appears that says
LabView.exe occured an error. And then the LabView process is killed
automatically.
Because of other problems with the same machine I decided to reinstall
the hole system new (OS and LabView). So i hope it will be function
after this.
Otherwise I will try to send you a part of the vi, which causes the
error. I only know that it dependce on the integrated Vi to write
LabView Measerument Files, because when I take it out the System runs.
Thank you for your answer and I will tell you if the reinstall of the
system has solved the problems.
Achim Kanert
(2,698 Views)
