LabView convert .csv data to analog voltage output with LV-Link
I am trying to take a CSV file using Read Delimited Spreadsheet, Index it into an array, load it into DtInitDACBuffers, and provide values for DtOLWaveformGenerate to output into a waveform on a DT9834 data translation device. One problem I have encountered is that after indexing the array and trying to send the values to the buffer, I get this:
The type of the source is 1D array of
double [64-bit real (~15 digit precision)].
The type of the sink is long [32-bit integer (-2147483648 to 2147483647)].
Is there a way to convert this?
Any advice on how I might achieve what I am trying to do with LabView or if it is even possible?
Thank you for any help.
(1,761 Views)
Hi Tareyes,
Have you explored data conversion pallet under numeric?
This may solve your problem.
X
(1,754 Views)
Accepted by topic author tareyes
Hi tareyes,
@tareyes wrote:
I get this:
The type of the source is 1D array of double
So you have an array of DBL, but the data sink only accepts an I32 scalar value?
What about indexing an element from your array?
(1,725 Views)
