LabView compatability
I have an old version of labview v7.1, with USB6008/6009 DAQ, installing on Windows 7 32b machine, can seem to get the USB tool loaded and working.  Are there driver - system compatability issues I am unaware of?
thanks
(3,112 Views)
DAQmx and LabVIEW: https://www.ni.com/en/support/documentation/compatibility/16/ni-daqmx-and-labview-compatibility.html
7.1 means you can work with any DAQmx 7.2-8.9
DAQmx and Windows: http://digital.ni.com/public.nsf/allkb/90FD507D9CACE4A886257C6D00594EA2
The first version of DAQmx supported in Windows 7 is 9.0.1
In order to remain on 7.1, you'll need to work on Windows Vista or XP.  If you want to use Windows 7, you'll need to be on at least LabVIEW 8.2 to be compatible with DAQmx.
(3,105 Views)
