LabView and parameters WAV of a file
At reading WAV of a file it would be desirable to know sample rate (frequency of digitization) that with the same frequency to write down results of processing. Function Snd Read Wave file gives only value rate. Whether It is possible, knowing value rate to define frequency of digitization, or it is necessary to create the function which assorts heading WAV of a file? Can be eat ready functions which allow to define parameters of audio of files?
(2,523 Views)
Hi, tumanovalex.
I'm not really sure what you're asking. Do you have a question about specific inputs or outputs of the sound VIs? Also, what version of LabVIEW are you using? If you can explain your question a little differently, I'll see if I can help. In the meantime, take a look at this example program that reads data from a sound file. Good luck!
Sarah K.
Search PME
(2,509 Views)
