LabView and excel workbook find value problem
Ok I have banged my head against the wall enough I must be missing something. I am trying to open an excel workbook go to a specific sheet find a value and insert a different value in the same row but a different column. I can do this for the most part, where I run into a problem is if the value that I am searching for is placed in the worksheet I am searching via a formula. I get an error. Here is a quick excel workbook and part of the VI that I am working on that is having the problem. Hopefully someone can see where I am going wrong. This VI is in LabView 7 and I am using office 2000. The sheet I am searching is test sheet.
-D
Message 1 of 9
(4,547 Views)
Wire numerical "2" to the "LookAt" input of the Find method.
-Joe
Message 2 of 9
(4,547 Views)
Thanks for your quick answer Joe. I tired what you mentioned and if i did it correctly I am still having the same problem. I have attached the modified vi.
Dave
Message 3 of 9
(4,547 Views)
If you receive error 97, then it means the search found nothing (labview therefore can not generate a valid reference). In this case, check the Find ref value using "NaN/Path/Num.vi" right after the "Find", when true, skip the next step.
-Joe
Message 4 of 9
(4,547 Views)
Joe
I appreciate your patience and help this is the first time that I am trying to work between LabView and Excel.
Error 97 is the problem I am having now, after wiring a �2� to the LookAt input of the find, but the value I am searching for is in the workbook and on that sheet. I think the issue is somehow that the value is placed there via a reference to another page so the cell with the value contains a reference i.e.� =Sheet3!G18� but displays the value I am searching for. If I remove the reference and write the value in the cell I find it ok, otherwise I get an invalid refnum. I tired wiring the LookIn input of the find to look just at the values which is the same way it needs to be searched within Excel. I then come up wi
th error -2147352571. I tried setting the LookIn by trying values of xlValues, various numbers, Values, xlValue, and Value but none of these seemed to work. I know in writing a Macro it would be �Lookin:=xlValues�.
Dave
Message 5 of 9
(4,548 Views)
please check the attached image, and pay close attention to the circled parts.
-Joe
Message 6 of 9
(4,547 Views)
Thanks Joe that worked great. I really appreciate your help. One question out of curiosity the value FFFFEFBD that is wired to the LookIn input how did you determine that and what is it�s meaning?
Thanks again for your help and patience
Dave
Message 7 of 9
(4,547 Views)
I have a book (sorry, can't recall the name) which lists all the constant values, but here is a webpage.
http://www.geocities.com/ResearchTriangle/9834/msexcel8.htm
or, you can go into VBA editor in Excel put this piece of code in there:
sub test()
debug.print xlValues
end sub
Press F5 to run it. The result will be shown in the immediate window (CTRL+G). In this case, it is a negative value.
-Joe
Message 8 of 9
(4,547 Views)
drhovasse,
Can you please post the final version of this functionality so I can compare between the previous two versions you posted? I may need this in my application. Thanks!
Message 9 of 9
(4,518 Views)
