LabView Windows and LabView Real-Time
Is it possible to run two applications, one on LabView Windows and one on LabView Real-Time target, at the same time on the same computer?
Ann
(3,029 Views)
Ann,
I have been replying to your previous message about using a Joystick with LVRT. I think your question comes from there. Look at the answer I posted there.
As far as this question goes, it is possible to have two applications running at the same time on two different targets, launched from the same computer.
When you are targeted to the RT machine, you will have the application started. The you can simply select Operate>>Switch execution target>> LabVIEW for Windows. This will let you move away from the RT target without closing the RT application that is running. This is what is normally done when debugging RT applications that communicate with a Host application.
From the questions you are posting, it seems you are not very much familiar with the LVRT platform. Consider getting in touch with one of our AEs on the phone for more specific support and information. Contact NI Italy at 02.41.30.92.17.
AlessioD
(3,025 Views)
Hi Ann,
Yes you can have two versions of LV running on the same PC -- one for Windows and another targetted to RT.  See the following thread for two ways of doing this:
http://forums.ni.com/ni/board/message?board.id=170&message.id=146243
-Khalid
(3,019 Views)
