LabView Unable to Resize Camera ROI
I am using a PixeLink PL-D752MU-T camera, NI MAX (driver 22.5.0.49198) and LabVIEW to image a sample.
However I recently updated my cameras drivers, and some settings, and the LabVIEW code (SetCameraProperties.vi) is no longer properly working. SetCameraProperties.vi is supposed to show the entire camera frame, then allow me to manually reposition a 192x192pixel ROI, changing the ROI to that frame (ResizeROI.png is a portion of the code focused on resizing the ROI). However, the vi can no longer change the ROI. In addition, it doesn't produce an image when I set the ROI to something other than 1920x1200 pixels, ruling out manually setting the ROI in NI MAX.
The LabVIEW code has not changed, so somewhere in the settings I seem to be overriding LabVIEW. I have also used PixeLink capture and its associated drivers in the past, and found that they could still set camera settings, even when uninstalled and deleted. So it is also possible PixeLink capture is overriding LabVIEW.
What can I do to troubleshoot this issue, what settings should I be looking into? My goal is to not modify LabVIEW code, as this is only a portion of my LabVIEW code infrastructure.
Message 1 of 1
(619 Views)
