LabView TabControl Refnum bug?..
LabView 6.0.2 is getting crashed if to create new control (not a VI!), then to create Control Refnum and to drag&drop TabControl into it. Immediate memory fault follows together with LV crash.
However if to assign VI Server Class explicitely by right clicking reference and selecting "Select VI server Class -> Generic -> GObject -> Control -> PageSelector -> TabControl" then everything goes fine. The problem is that I still want to be able to create TabControl's "strict type" refnum in order to avoid type cast while using this refnum, does anybody know how to do that?
(3,059 Views)
Place a Tab Control on a VI front panel, then create a reference to the control,this will appear on the diagram. Then you can copy this reference from your block diagram to your VI front panel. It will have the strict typed.
Regards
Ray Farmer
Regards
Ray Farmer
(3,059 Views)
