LabView TCP decimal / ASSCII
Hi
I send from one pc through LAN via LabView tcp-client decimal numbers or characters to another pc  tcp-server which is written in java.
The communication works, but my problem is: when i send decimal 1, i receive at the server side 49, that means i get at my server the ASSCII code for decimal 1 which is 49.
Cna somebody helpme please?, i dont know what should i set or change that the LabView send the right character or number wich i desire?
Thank you very much
Kami
(4,125 Views)
The anwer is YES.  You should expect to get this response.  Convert the Dec back to ASCII.  I don't think it is a mode.  TCP sends strings so it depends on how you convert your numbers before you send the data.
Matt
Hex  Oct  Dec  ASCII
30  060  48  0
31  061  49  1
32  062  50  2
33  063  51  3
34  064  52  4
35  065  53  5
36  066  54  6
37  067  55  7
38  070  56  8
39  071  57  9
Message Edited by mfitzsimons on 05-17-2006 11:22 AM
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(4,113 Views)
The problem seems to be with your server side, not with the LV program - the LV client sends a single byte with a value of 49. The server should know how to translate this into a displayable ASCII character. You could modify your code to send out ASCII 1 instead of ASCII 49, but that wouldn't really make any sense.
___________________
Try to take over the world!
(4,107 Views)
