LabView - Single Task Export to .INI file
Hi all
Can anyone suggest a solution to export a single DAQmx task to ini file programmatically?
Description: there are several calibration tasks created by LabView and saved using "DAQmx save task.vi", one for each connected cDAQ module.
Clearly, It is possible to export a distinct task using MAX import/export wizard. However, when I use Export.vi (System Configuration/Utilities) it creates a single file that contains information for every task existing in MAX.
Q.: Is there a way to programmatically select and export a single task?
Thank you in advance..
Message 1 of 1
(1,623 Views)
