LabView Multi-Column List Box Configuration
I am using LabView 2017 and for some strange reason when I tried to use the Multi-column List box, I was not able to select a row and highlight it.  Even after enabling the "Selection Mode>Highlight Entire Row" in either edit mode or run mode, the Multi-Column List Box appears to do nothing.  Has something changed in the "Multi-Column List Box" control/indicator?
(2,687 Views)
You are not able to select a row that is empty - do your rows have data?
(2,646 Views)
