LabView, FieldPoint and linux ?
I'd like to use FieldPoint modules to build a cyclotron control system and I do
want to use linux as developpement system.
I saw that LabVIEW is available under linux but what about FieldPoint Explorer
and LabVIEW-Real Time ?
What software is absolutely necessary to developpe FieldPoint software under
linux ? And is it possible or not ? Do I need to use Windoz ?
Thanks for your answers
Denis
(2,875 Views)
Denis,
There are two different answers to this question, both of them is that it is possible albeit not with as much freedom as a Windows machine offers.
Answer 1 is that using the FP-1000/1001 Programmers Reference Manual you can communicate with FieldPoint serial modules from any OS/computer that has a serial port. This solution works with FP-1000 & FP-1001 Netork modules ONLY. No other network modules (FP-1600, FP-2000,FP-2010,FP-2015,FP-3000) can be used with this approach. All of the commands documented in the FP-1000/1001 Programmers Reference Manual, are encapsulated in two LabVIEW libraries which should work on all OS's that LabVIEW works on). The libraries can be downloaded from: ftp://ftp.ni.com/support/fieldpoint/LVFPOpto/
Answer 2: Using the F
P-20XX modules, you can use a LabVIEW RT machine on Windows to download code into a FP-20XX module with that makes data available via custom communication routines (either serial, TCP or UDP based). In this way, you need a Windows machine to do the initial development, but the code will run on the Real-Time OS in the FP-20XX module and communicate to your Linux based machine.
In either solution, you do not have FieldPoint Explorer available, unless it is on a separate machine that is used solely for configuration purposes.
Aaron
LabVIEW Champion, CLA, CPI
(2,875 Views)
