LabView FPGA ERROR:place:543
Hi folks, While i'm compiling my FPGA vi, i have got the device utilization report as 76%...while phase 13.9(during mapping) calculation i'm getting Error:Map:543. placement constraint error..Give me a solution to resolve this issue... Thanks in Advance....
(3,133 Views)
Hey,
What software and driver version are you exactly using?
What is the hardware you are using?
Do you see this with a certain VI or with every VI you try to compile?
Christian
(3,126 Views)
Thanks for your response....
i'm using LV 8.6.1 and RIO version is 3.1.0.
H/Ws are
Controller - cRIO-9014
Chassis - 9114
AI - 9205
AO - 9263
DO - 9476
DI - 9425
Basically i have two FPGA VIs. One VI which just fetches the AO channels' offset & LSB and i could compiled it. Another one i have put the FIFO and other main logics and that could not be compiled..
Here i have attached the compilation summary which i got...
Thanks....
(3,105 Views)
So the problem is just with a specific VI. Could you post your VI here?
Christian
(3,046 Views)
Hi Folks,
I've got through from my issue. The culprit is FPGA compiler which i brought with my LV DVD pack..Finally i reinstalled LV with another pack.
Thanks a lot!!!!
(3,038 Views)
