LabView Express v8.6 Processing and the analysis of signals activation problem
We've bought the NI USB-6008 device vith LabView express v8.6 CD. In DEMO mode was made the project, but after activation of the Lab View it is not work the processing and the analysis of signals functions. In our prodjct these functions are very important. What should we do in this case?
(2,499 Views)
There is Signal Express and LabVIEW but neither are version 8.6 so I'm not sure what you bought exactly. If you did buy LabVIEW and activate it and the signal processing/analysis functions do not work, then perhaps what you bought was the base version of LabVIEW. The base version does not include these functions. The evaluation verrsion of LabVIEW includes everything. When you select Help>About LabVIEW, what does it say? If it says full or professional, you should have those functions.
(2,486 Views)
What do you mean by it is not working, what exactly is it doing. You may want to check to see which version of labVIEW that you have licensed. When you run LV in the evaluation mode you get the full version of LV and all the VI's but when you activated it with your license then you may only have the base version of LV. Some analysis VI's are not included with the base version of LV. See what version you have registered by going to the license manager.
This may be what is going wrong.
Joe.
"NOTHING IS EVER EASY"
(2,481 Views)
