LabView Executable files
I had a question about LabView executables files- (one of the main differences between LabView Full and LabView Professional).  If I am able to create LabView executables (LabView Pro), then I would be able to run LabView programs (executable files) on PCs that do not have LabView installed?  If I use LabView Full (no executables created), then I can only run LabView files from PCs that have LabView installed?
Alex
Message 1 of 11
(4,406 Views)
Your statement is correct. Was there a question?
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
Message 2 of 11
(4,402 Views)
You will need to install the correct LabVIEW runtime engine on any computer that will run your exe.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 11
(4,399 Views)
Charles,
I am looking to buy a LabView licence and I just wanted to make sure that I understood the difference between LabView Pro and LabView Full.  I am planning to have 1 licence but I would need to run programs on different PCs so it seems that we would need LabView Pro.
Alex
Message 4 of 11
(4,397 Views)
As a long time user of LabVIEW and someone who is not in any financial way affiliated with National Instruments, I would highly recommend the Developer Suite over the Pro version. I believe the cost to benefit ratio to be VERY high.
Charles
Charles Chickering
Message 5 of 11
(4,394 Views)
Charles
I agree completely. Besides, once you add one or two of the essential toolkits to the pro version you are at about the same price as the developer suite.
Mark Yedinak
LabVIEW Champion
Message 6 of 11
(4,390 Views)
Charles
Well I should have said the benefit to cost ratio is very high Smiley Wink
Charles Chickering
Message 7 of 11
(4,383 Views)
The price difference does not seem that big... I dont think we will need to use the additional features of LabView for now (such as more robust signal processing, etc..).  But if at a later data we decided to upgrade, would we just pay the $500 difference?
Alex
Message 8 of 11
(4,364 Views)
I don't think you will. It does cost more to upgrade than the cost differential when you initially purchase it. However you should verify this with NI sales.
Mark Yedinak
LabVIEW Champion
Message 9 of 11
(4,359 Views)
The feature in Develop Suite that we could be interested in would be Report Generation to MS Office.  Can LabView Pro generate reports in csv or txt formats?
Message 10 of 11
(4,351 Views)
