LabView Driver
I need to create LabView driver to control a pump - Variable Frequency Drive (VFD). Does anyone in here have the LabView driver code to share with me?
(2,707 Views)
That depends on how you want to control the VFD drive: analog output (0-10vdc or 4-20ma), serial port (modbus protocol??), digital I/O points?? What is the part number and manufacturer for the VFD drive?? What hardware are you using to run the labview application (PDA, computer)???
(2,698 Views)
