LabView Code
Hello guys
I have a case structure in an event case and using enum now for some reason the code keeps skipping over some of the cases. Any idea on how to resolve this issue.
Thank you in advance
(3,386 Views)
Yes.  You've just made your block diagram incorrectly, that's all.  Just fix the mistakes and it will be fine.
(3,369 Views)
It's annoying that computers do what you tell them to do, and not what you want them to do.  With experience, hopefully the two converge.  😉
Bill
CLD
(Mid-Level minion.)
(3,341 Views)
You might notice that you got two absolutely correct, absolutely accurate response that are probably absolutely of no use to you.  Why is that?  Because you provided us absolutely no information on what you did!  Now, if you had attached your VI (not a picture, as we can't "execute" a picture), we would be able to give you more helpful comments.
We're pretty good, but we can't read your computer screen from here ...
(3,338 Views)
I want it to be that the mouse I'm touching works on the screen I'm looking at, and is connected to the computer i'm thinking about.
(3,326 Views)
Me, too.  I've got my Work Laptop and my Home Laptop together at home, both with identical Wireless Trackballs.  Too often I pick up the "mouse" and say "Why is this not working?", only to see the cursor whizzing around on the other machine's screen ...
(3,283 Views)
