LabView Capabilities
I need to find out if:
1) Can LabVIEW graph RTU/Modbus output Temperature vs Time
2) Convert RTU Modus output from temperature controller to 0-10 V or 0-5 V output, and plot it as Temperature.
Thank you!
(3,593 Views)
  1. yes
  2. yes
(3,568 Views)
Thank you! Do you have a tutorial or step-by-step instructions how to do it? I am new to this software and don't even know where to start.
(3,563 Views)
Well, LabVIEW is a general purpose programming language, not just a turnkey solution. Start with some tutorials.
(3,561 Views)
There are a few ModBus libraries floating around that you can use to get your data.  From there, it is simple math to get your engineering units.
(3,539 Views)
Oh there's lots of free training, here are the typical links shared on the forums.
NI Learning Center
NI Getting Started
-Hardware Basics
-MyRIO Project Essentials Guide (lots of good simple circuits with links to youtube demonstrations)
-LabVEW Basics
-DAQ Application Tutorials
-cRIO Developer's Guide
Learn NI Training Resource Videos
3 Hour LabVIEW Introduction
6 Hour LabVIEW Introduction
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
Remember LabVIEW is a programming language.  If you are asking yourself if you can do something in LabVIEW, ask yourself if you can do this in C?  Or VB?  If the answer is yes then (in almost all situations) you can do it in LabVIEW.  By the way the Class based Modbus code from NI is the ones I typically use which I think come with LabVIEW RT, but maybe also the internet connectivity toolkit.
(3,488 Views)
