LabView Base Edition and DAQ Analog Output
Can the Base Edition of LabView 2019 drive the analog output of an NI USB-6001 DAQ device ?
(3,529 Views)
Yes.
As soon as you have DAQmx installed…
(3,520 Views)
Thanks for your quick response GerdW.
So, by needing to use DAQmx this means that the built-in DAQ Assistant with LabView Base can not be used to drive the outputs?
(3,503 Views)
Hi cthomas,
I'm not sure about those ExpressVIs - never used that plain Base version.
But you are better off without that DAQAssistent as DAQmx is really easy!
(3,488 Views)
That doesn't make any sense.  There is on "Built-in DAQ assistant with LabVIEW Base.
The DAQ Assistant gets installed when you install DAQmx!
(3,474 Views)
Thanks Ravensfan.
I'm running the eval copy right now. Just trying to fill in the blanks that the "Selecting your Labview Edition" web site leaves open.
I have noticed some contradictions on that table.
One in particular  regarding to Base Edition.  At the top there a note that says "includes basic math and signal processing"  and down in the list "signal processing" is unchecked as if it would not be available.   Some web crawling leads to the answer that basic signal processing is available in Base Edition.
I have run into a similar situation with the control of analog outputs on Base Edition.  No answers I can find for this one.
Which brings me to the forums.
(3,467 Views)
I am not familiar the table you are referring to.
I do know that there have been some things that were added to the Base version that weren't there several years ago.  For example, event structures.  It is possible that some of the advanced processing algorithms were added, but I don't know.  If they were, then possibly some references you found pre-date their addition to Base.
And I think while you are in evaluation mode, you can try out the fuller versions of LabVIEW to determine if they meet your needs.  Of course when the evaluation ends, you'll have to purchase whichever version you truly need.
But none of this relates to whether DAQmx is installed or not.
(3,461 Views)
