キャンセル
次の結果を表示
次の代わりに検索
もしかして:
LabView Application Builder cannot find files
I am able to successfullt create an Application (.EXE) for a LabView project, but when I try to create an installer, I get the following message:
"The build was unsuccessful.
  Possible reasons:
The following file(s) are not found on the system:
<Not A Path>
<Not A Path>
<Not A Path>"
Details:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_PreBuild.vi >> CDK_Engine_FileExists.vi
0 件の賞賛
メッセージ1/15
7,685件の閲覧回数
If you create a new installer from scratch and just add one piece at a time, what happens?  Does it fail if you only include the .exe?  Or does it fail when including other files?  Can you post your code?
Daniel Eaton
Systems Engineering
Embedded and Industrial Control
0 件の賞賛
メッセージ2/15
7,666件の閲覧回数
I created a new installer from scratch, and it worked.  Thanks!
0 件の賞賛
メッセージ3/15
7,648件の閲覧回数
Excellent!
Daniel Eaton
Systems Engineering
0 件の賞賛
メッセージ4/15
7,630件の閲覧回数
  Possible reasons:
Details:
Hi Brendave,
Any chance you could post some files that reproduce the error you reported? I'd like to investigate how/why the installer builder failed when trying to include your exe. Thanks and happy holidays.
-Bob
メッセージ5/15
7,484件の閲覧回数
Bob,
I deleted the installer script that caused the error.  I am guessing that I created the project by copying an existing project and then editing some of the files.  I make a lot of similar projects, and I reuse a lot of code, so it's easier to copy a directory and then work from there.  That may be the reason the App builder failed.  Merry Christmas!  Thanks for your support.
Message Edited by brendave on 12-21-2007 12:23 PM
0 件の賞賛
メッセージ6/15
7,480件の閲覧回数
@brendave wrote:
Bob,
Gotcha, alright well if it shows up again, lemme know. Perhaps after the .lvproj file was copied, some of the source files were moved or renamed, rendering the installer build spec invalid. Dunno, just guessing.
0 件の賞賛
メッセージ7/15
7,474件の閲覧回数
i build a application based on my  vi but my not working properly but the vi works good.plese clear my problem
0 件の賞賛
メッセージ8/15
7,452件の閲覧回数
Hi Jabili,
To help with searchability, I would create a new discussion forum thread.  Unless the problem is somehow related to creating installers.  From your previous post it sounds like when you run your VI it operates correctly, but when you turn it into an executable the functionality changes.  The easiest advice I can offer to you is to make a debuggable executable.  This feature was only recently introduced, so if you have LabVIEW 7.X or earlier you cannot make a debuggable executable.
Also, if you create a new thread I would include what version of labVIEW, and a description of the error, and any other relevent information to help  everyone who is trying to help you :).
Brian K.
0 件の賞賛
メッセージ9/15
7,421件の閲覧回数
I succesfully build the application (.exe) but when i tried to build the installer, it was unsuccessfull and here's the possible error:
CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_Build.vi >> NI_MDF.lvlib:MDFDistCopyList_CopyItem.vi
Loading product deployment information
Adding files to installer
Done adding files
Preparing to build deployment
Copying products from distributions
Copying distribution 'Setup' from: H:\ENG\SoftwareDev\SDF97900371 - JSF Host\Software Code\JSF GUI Installer\Volume\ to: C:\Documents and Settings\wibawaa\Desktop\Builds\JSFHost\JSF GUI Installer\
*** Error: Windows SDK function returned an error. (Error code -12)
The system cannot find the file specified.
*** End Error Report
Done building deployment
any tips how to fix this?
0 件の賞賛
メッセージ10/15
6,519件の閲覧回数
