LabView 7.1 & RT plugin
Hi!
I have a problem. I've ever seen a remote VI.
During last 2 weeks, I can't see a VI through Run-time service of LabView
7.1. Using an other PC, I can see the VI.
I have installed LabView 7.1 with Run-time and I've checked the correct
plug-in (I installed also for Firefox).
I repaired RT installation and then I re-installed LabView 7.1.. but none.
Using the PC of my collegue, I can see the remote Panel VI!!! Why?
I use Windows Vista, with its Firewall (I shut off it, but none).
Anyone can help me?
Marzio
(2,901 Views)
Hi Marzio, make sure you have downloaded and installed the latest plugins.
Also, have you tried this with just Firefox or have you also seen a problem with Internet Explorer?
Finally, can you post a screenshot of the error or warning message that is being displayed and if there is none, then a screenshot of what happens when you try and view one of your Remote Front Panels?
David_B
(2,883 Views)
yes 🙂
FF & IE: they load the plugin (if I delete the plug-in, both FF and IE tell
me that a plug-in missing), but they can't load the VI.
There's no error message. Simply the message "Downloading Panel 0% of 0
bytes". But with an other PC, I can download the front panel..
Thanks 4 the help
(2,874 Views)
Let me know if this forum post solves your problem.  There is an issue with certain anti-virus programs that affects remote front panels.
David_B
(2,869 Views)
