LabView 6.1 subVIs cannot be opened under 7.1.
Some subVIs written under LabView 6.1 cannot be opened under 7.1 with the argument, that they have no block diagram! Surely they have, and when one tries to open the VI, message for error code 11 appears, and the Vi is left closed. How can be this problem solved?
(2,754 Views)
Do you handle images in your VIs
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(2,754 Views)
No,definitely not!
(2,754 Views)
It's certainly possible that they might not have a block diagram. That is an option when saving VIs and often third-party vendors will distribute VIs that way as a security measure. When creating an LLB meant for an executable, the diagram will be removed as well. Where did the VIs come from? Can you attach one of them? If they truly have no block diagram, then there is nothing that can be done. Once deleted, the block diagram is gone forever and without a block diagram, a VI cannot be recompiled for a newer version of LabVIEW.
(2,754 Views)
