LabView 6.1 compile issue
we have trouble to build an application (make a exe file) from a LabView Programm.
The error message is as follows:
Error 1 Occurred at PIN Calibration.vi:\.
LabVIEW: An input parameter is invalid
NI-488: Command requires GPIB controller to be in charge
Any ideas how to solve the problem.
Thank you very much!
Stefan
(2,662 Views)
When you build an application your SW i recompiled. Mayby this recompile
causes the problem because dll, referencer and other stuff are reloaded. The
dialogs with these problems are not good. But you can for a recompile of
your application. Press the RUN buttom while pressing SHIFT and CTRL. When
you will see compile problems as a broken arrow.
Morten Pedersen
"STSC" skrev i en meddelelse
news:506500000008000000B3CD0000-1079395200000@exchange.ni.com...
> Hello,
> LabView Programm.
> Any ideas
> Stefan
(2,662 Views)
