LabView 5.1 and MS Access
Is there a simple way to communicate with MS Access Database under Labview.
I tried sample code found in the package but DDE is note very good and
require Access to run behind.
I also tried putting some DAO object (ADO+DBGRID using activeX object)
but not found the way to access object property such as recordsource,tablename, ...
Note : I'm a newbie with labview i'm a bit confused with the graphical language
(2,820 Views)
In article <39103E34.8D599620@actris.com>,
Labview.
yes, there is. Try our DAO toolkit (demo at www.xon.de), which is a
high-level-interface for the jet-engine.
Peter
Sent via Deja.com http://www.deja.com/
Before you buy.
(2,820 Views)
