LabView 2022 Q3 code generation failed to execute
Please advise why NI doesn't have a working set of drivers for the DAQ assist. I just loaded LabView 2022 Q3 and I'm receiving 'LabView Code generation failed to execute'. How do I get someone at NI to address these issues? I notice from previous post that this was an active concern in 2011. I found it hard to believe it's still an issue today.
Message 1 of 11
(4,674 Views)
I am not sure what "loaded LabView 2022" actually means. Did you just install it, as we as all the drivers?
Message 2 of 11
(4,650 Views)
Yes, install/loaded 2022 Q3, along with the DAQmx drivers and other recommended files. I’m using a 6501 USB and when I try using the DAQ assist it doesn’t build the VI. I get a pop up error that says’LabView code generation failed to execute’.
Message 3 of 11
(4,638 Views)
Can you show a list from NI MAX of the software you have installed?
Message 4 of 11
(4,625 Views)
Have a look here for a workaround. (bug# 2065508)
(See also this recent thread for more details)
Message 5 of 11
(4,624 Views)
see attachments
Message 6 of 11
(4,563 Views)
It is not useful to attach pictures without explanation. (Also note that you can embed images directly in the post to make our life easier. Just click on the camera glyph or even paste the image directly into the edit window.)
As I already said, this is apparently a known bug and the current workaround is listed in the link I gave earlier. Did you look at it?
I would think this bug has a very high priority and I assume it will get fixed in an upcoming patch.
Message 7 of 11
(4,557 Views)
The work around suggest installing 2021 SP1, unfortunately my base subscription does not offer this application from the software downloads. This release is grayed out and I can only download the community or runtime for 2021 SP1.
Message 8 of 11
(4,551 Views)
Are you sure you're logged into the correct account?  You should be able to download and use earlier versions of LabVIEW - unless they've taken that away from us as well with the new subscription license.
Bill
CLD
(Mid-Level minion.)
Message 9 of 11
(4,516 Views)
Can you install LabVIEW 2021 through NI Package Manager that you have installed?
Message 10 of 11
(4,503 Views)
