LabView 2020 and cRIO-9025 with NI-9219 module compatibility issues
Hi, I have a cRIO-9025, NI-9219 module, RT LabView, FPGA, and LabView 2020 running on Win10. NI-Max (version20.0.0f0) recognizes and sees the CRIO-9025 with all the information (IP address...), but does not recognize the NI-9219 module under “Device and Interfaces” tree. Also, from LabView 2020 project when adding “Targets and Devices” LabView displays “cRIO-9025 (Link-local IP Address)” with exclamation mark saying “This device is not supported by your LabVIEW Environment”. I have checked the cRIO-9025 compatibly with LabView on NI Website and shows minimum is LabView 2019. Has anyone tried to install and use cRIO-9025 with Win10 and LabView 2020 platform successfully? Thanks! Ray
Message 1 of 1
(1,322 Views)
