LabView 2020 FPGA Disable Structure
Accepted by topic author Edmund130
@billko wrote:
Under your project's properties, you'll see this:
This is where you set the conditionals.  Note that this is set during development and the FPGA gets compiled with those symbols and values.
Edit: I saw that you said you looked in the project's properties.  Is this what you said you couldn't change?
The above is the Project properties.  You will see FPGA specific properties under the Target's Properties.
ALE Consultants
Message 11 of 11
(570 Views)
